Disconnect Switch location on 2014 21QB Coachmen Class C
Brian S
Junior Member
I have recently purchased a 2014 21QB class C Coachmen Freelander motor home and am in the process of winterizing it. I want to disconnect the coach battery from the unit but cannot locate the disconnect switch. The RV does have a solar panel on the roof that does aid in charging the battery. The owner's manual talks about the disconnect switch but does not point out its location. I would also add that the owner's manual is generic for several of Coachmen's RV models and thus does not necessarily pinpoint where everything is located. Does anyone know where the switch may be located? I have looked everywhere and cannot locate it.
Dont know about YOUR coach but as a general rule it should be either of two places, next to the entry door for the relay type or in the battery compartment for the manual type.
