Transforming your RV’s interior with custom curtains is a budget-friendly way to enhance comfort and style. Instead of buying expensive pre-made curtains, why not create your own? In this article, we’ll share DIY RV curtain ideas, including fabric choices, easy sewing techniques, and no-sew options.
Why Make Your Own RV Curtains?
- Cost-Effective: Save money by using fabric remnants or affordable materials.
- Custom Fit: Tailor curtains to your exact window measurements.
- Personal Style: Choose colors and patterns that match your RV’s decor.
Materials Needed for DIY RV Curtains
- Fabric (cotton, linen, blackout, or thermal)
- Measuring Tape
- Scissors or Rotary Cutter
- Sewing Machine or Needle & Thread
- Iron & Ironing Board
- Curtain Rods or Tension Rods
- Pins or Fabric Clips
Step-by-Step Guide to Making RV Curtains
- Measure Your Windows
- Width: Measure the window frame.
- Length: Decide on curtain length (floor-length, sill-length, or shorter).
- Cut the Fabric
- Add 1-2 inches to the width and length for hemming.
- Cut two panels if you want a fuller look.
- Hem the Edges
- Fold the sides and bottom edges twice (½ inch each) and sew.
- Fold the top edge twice for a clean finish.
- Add Curtain Rod Pockets (Optional)
- Sew a 2-inch pocket at the top for a tension rod or curtain rod.
- Install the Curtains
- Use magnetic rods, adhesive hooks, or tension rods for easy installation.
No-Sew RV Curtain Ideas
- Clip Rings & Fabric Strips
- Cut fabric to size and use clip rings to attach to a rod.
- No sewing required—just clip and hang.
- Velcro Curtain Solution
- Attach Velcro strips to the window frame and fabric edges.
- Easy to remove and wash.
- Beaded Curtain Alternative
- Use decorative beads or ropes for a boho-style divider.
Best Fabrics for RV Curtains
- Blackout Fabric: Best for bedrooms.
- Sheer Cotton: Lightweight and airy for living areas.
- Thermal Fabric: Great for insulation.
Styling Tips
- Layering: Combine sheer and blackout curtains for flexibility.
- Tiebacks: Use ribbon or fabric ties to create a stylish look.
- Patterns: Mix and match patterns for a playful vibe.
