DIY RV Curtain Installation: Budget-Friendly and Stylish
ttstt
Member
1747359539979.png​
Your RV is your home on wheels—why not make it feel that way with custom curtains? Unlike traditional home setups, RVs require lightweight, space-saving solutions. Here’s a DIY guide for installing curtains in your RV without breaking the bank or drilling unnecessary holes.
Why Curtains Matter in an RV​
Curtains help regulate temperature, block out sunlight, add privacy at campsites, and bring a sense of style to small spaces. They're especially useful for dividing areas like bunks or bathrooms.
Materials You’ll Need:​
  • Curtain fabric or pre-made RV curtains
  • Measuring tape
  • Tension rods or bungee cords
  • Curtain clips or rings
  • Velcro strips (adhesive-backed)
  • Scissors, if hemming
Step-by-Step Installation:​
1. Measure Your Windows
RV window shapes vary widely. Use a fabric measuring tape to measure both width and height. Add a few inches for coverage and seam allowance.
2. Select Your Fabric
Choose light yet durable fabric like cotton, polyester, or linen blends. For privacy, opt for blackout lining or dual-layer curtains.
3. Choose a Mounting System
  • No-drill tension rods work well for upper window frames.
  • Velcro + fabric combo is ideal for ultra-light setups.
  • Bungee cords can be threaded through curtain grommets for rustic charm.
  • Magnetic strips are perfect for steel-framed RV windows.
4. Hang and Test
Attach your curtain to the rod or Velcro, then mount everything in place. Open and close a few times to ensure it slides smoothly and stays secure on bumpy roads.
Extra Tips:​
  • Hem or pin your curtains to prevent dragging or clutter.
  • Use command hooks for holding curtain tiebacks.
  • Try insulated or reflective backing if you’re traveling through hot/cold climates.
Budget Tip:​
You can even repurpose home curtains by trimming and sewing them to fit RV dimensions. Add snaps or magnets to make them RV-friendly.
Installing curtains in your RV is an easy weekend project that can dramatically improve comfort and design. Plus, it’s a fun way to express your personality—even while on the road.
Back
