Dometic Fridge Blowing Fuses
rjf7g
I have a 2007 Dometic DM2652 and it had a blown 5 A fuse - in the fridge, not at the inverter. I got a few 5 A fuses at AutoZone and the fridge has blown two of those. I checked the voltage at the outlet and it is 116.8 V. I have the fridge running off of gas right now. Any ideas as to what might be wrong? Thanks!
G
Guest
Guest
RE: Dometic Fridge Blowing Fuses
becky ,, was this the fuse on the main board??? if so ,, u might have a shorted element ,, btw did it blowthe fuse right away ,, when u replaced it ??? if so ,, i think the element is bad ,, :(
rjf7g
Re: Dometic Fridge Blowing Fuses
Rod-
Yes, it was on the main board and it blew right away. GTS gave me directions to confirm that it's the board. Thanks!
