Hi all, I'm new to this forum.
I recently purchased a 95 Bounder. It is a low mile super clean unit.
The only problem so far is the fridge. It cools great on both ac and gas. When on gas the check light comes on after about 24 to 36 hrs of operation. Turning it off then back on it works great on gas for another 24 or so hrs.
I'm a handy sort of fellow so I have researched and performed routine maintainence including cleaning the flue, adjusting the igniter, etc.
I found a website that will sell a CD with Dometic service manuals and service bulletins including
the following.
The "Check light" problem bulletin. A good place to start if you are having the dreaded "check light comes on" trouble - Pay close attention to the rewiring instructions - Dometic Bulletin R70/4B
My question is should I be full of DREAD? Is anyone out there familiar with this problem?
Should I buy the CD?
The fridge is a Dometic model RM2807. It works fine on AC. I need it to work on gas as I dont hook to shore power very often.
Any help will be greatly appreciated Thanks.
the following.
