Electical Probelm
Terry 6,
Wondering what happend with the 12V power problem. As a retired tech. I just have to know more about this one. Since starting the genset solves the problem it has to be related to the 12V supply. When you start the genset, you are supplying 120V-AC to your converter and it in turn is supplying the extra 12V-DC power to get you back up again. A motorhome genset does not supply any 12V-DC, but only supplies 120V-AC which supplies the converter. You didn't say how old the batteries are or if you have taken a close look at the cables and the connections to them? I would look at them very closely and if you have not done so, clean the cables and the battery posts very carefully. You may want to use a dialectric grease (which you can buy and any home supply store) to them as well just to improve the connection.
In thinking about your problem, it seems as though it happens when you increase the power requirements by turning on something. Do you turn things off when you start the genset to get it going again, or just leave them on and let the converter assume the load?
Here is another test just to confirm that the converter is what is picking up the load. Try running the DC with shore power available, but not connected, then plug in shore power when the 12V power fails. I bet that will make the problem go away as well. But that still doesn't answer what is happening?
Do you have a schematic of the electrical systems? This has to be a problem in the area of the batteries, or some common point. In most RVs the output of the converter is connected to the battery terminals as the connecting point for all loads, the battery and the converter. To me, it seems that the problem has to be either in the connections or the batteries. You don't say if you have one battery or two, but if two, try removing the batteries one at a time and see if using only one battery makes a difference.
And keep us posted as to what is happening!
