Re: electric steps problem again
DogMan,
My steps on previous M/H used to give me fits. They had a mind of their own thats for sure. Hollis is spot on about regular lubrication due to road grime etc.
Did your steps retract without your assistance in the past when you started the engine? If so I'd be looking at your batteries, poor ground connection or converter. If I remember correctly steps will act erratically if you do not have a minimum of 30 amps. My steps irregardless of how much they frustrated me always worked/retracted perfectly when I fired up the cummins. I finally traced the wires and found the ground wire (green) had a questionalbe spot on the insulation and then applied some heat shrink to it and problem never appeared again during ownership.
Not sure if I made the proper fix but it worked for me.
Jeff
