Electrical Test Equipment, What do you use?
DadMac
I am looking for an inexpensive meter to test voltage and amperage at RV park hookups. Most meters I have found only go up to 10A. Any suggestions on what I should use to test a 30A circuit? I am new to RVing and any help would be appreciated. :)
zigzagrv
Dadmac, I use a meter called 'Kill A Watt' from RadioShack. Cost around 40-50 bucks and displays voltage, amps, hz, kwh when plugged into any 110 volt outlet. Also great for checking generator output.
Ron
DadMac
Thanks zigzagrv! I will check that out. I was in RadioShack, but was looking for the wrong thing. Sounds like just what I am looking for.
DadMac
