Engine compartment light
SURVEYOR1
I recently bought a '99 Tiffin Allegro 28WB.
There is an oval shaped light in the front under the "hood". I guess technically that wouldn't be the engine compartment. Anyway, when I first had the unit I couldn't figure out how to turn it on. Then, suddenly I noticed that it was on and now I can't figure out how to turn it off. If nothing else works, I'll put a switch on it, but it would be nice to know from whence the power comes. I looked real hard for a door switch to no avail.
BTW, I found the air valves on my duallies after looking harder.
Re: Engine compartment light
Well I don't know about at Tiffin Allegro, but I have switch on my dash on the left side of the steering wheel that controls the lights in the compartments and the hood light.
SURVEYOR1
We have a bingo !
Thanks H2, after pondering your reply it dawned on me that I had cranked the dashboard dimmer switch past the "click" and left it.
I noticed at the time that nothing came on. Well, as it turns out, what comes on is the light under the hood.
Problem, or lack thereof, resolved.
well that is what we are here for is to help each other out. So glad you have it solved.
G
Guest
Guest
Just think ,, Hollis is really an rv tech under cover ,, u had us all fooled Hollis ;) :laugh: :laugh: :laugh:
Rod all I know is for listering to you and Ken and others. I will have to admit, I have learned a lot for yall, thanks :laugh:
