RE: Every thing is beautiful!
Hi Kirk
Ed Here from Heber Springs Ar.
Hows it going for you today, I have a problem, even if I am not full time, does it count.?
I found a broken spring on my class A yesterday, just when I was going to use it after 2.5 years , it is a 97 HR with 2 springs on each jack. ( I know if you don't use it things happen )
I will need to order one or two, I can fix it, I can fix most things, except inside motors and transmissions.
You know when I emailed you a while back, and you said you think Workampers News is in Heber,
Yes it is, I have known the Robus's since they moved to Heber in about 1970. They had it in a brick house down by the Little Red River ( trout ) with a nice two story home for them on several acres,
I know they sold out.
and it is now in a remodeled house my older brother owned. in town.
When are you coming up here to manage the Corp of Eng. Lake or River campgrounds, it is very nice here, ?
Keep writting and I will keep reading your posts, I learn a lot from you and the other RV's
I know you are smart because you and I both used to be Electronic Techs.
Regards Ed
