Fleetwood Motorhomes
Xmike
I would just like to pass along to anyone that owns a Fleetwood Motorhome like the Jamboree should check the Welding on each side where the Frame Extensions are welded on. I think my coach got by Inspection without being checked. Also check the welds where the Generator is mounted, on mine is was about to let go. The problem was first pointed out to me during a front end alignment check my a Ford Service Center. They just happened to be checking along the frame and noticed the problem. I don't have the room to put all the pictures here but they can be seen at http://www.geocities.com/xmike@sbcglobal.net
Hopefully this will save someone from having an accident on the road. I almost did.
