Ford 6.0 problems
Hightower
Just joined the club with an 03 F250/6.0 engine. Bought it to pull our RV trailer. First cold night we had I noticed that it ran rough and smoked when I started it. Took it to the Ford House where they of course replaced number 6 injector. Still does the same thing, so on cold nights I plug the warmer up and it seems to help. One mechanic told me to change the oil and put 13 quarts of oil and two quarts of mercon trans fluid in it. He said the trans fluid will act like a solvent to clean the oil from injector spools. This should help the problem. Has anyone else heard of this or should I just take my 9mm and shoot now to take it out of its misery!!!!!!!!
Phil
Re: Ford 6.0 problems
One of my employees has a 2003 also. He has luckily had few problems but he has had the problem you describe. He took it in and they had an update just for this. After this re-programming, it is running better.
I have never heard of putting transmission fluid in the engine and I would be very hesitant.
get rid of it nothing but trouble from what I hear. go get you a Dodge or EVEN BETTER YET A 2500/3500 CHEVY DIESEL WITH A ALLISON TRANNY, that JMHP :)
Hightower
Thanks for the info. As far as the reprogramming, I ask the dealer about that and they said it was only for the 7.3. Were they right or does your friend have a 7.3. Phil
Use the 9mm. Nothing will help the 6.0L Ford Power Strokes. Especially the 03/04 models. :(
Hightower
Do you think it is worth the bullet. Actually I love the truck and it is in excellent condition. Other than the cold starting problems, it runs great. I am worried that on a long trip to the coast, we may have problems and that would be bad. Can't afford a lot of shop costs. Anyway, may have to take a chance. Phil
NO, my employees truck is a 6.0. Your dealer is WRONG. You must deal with the same dealer as I, that is why I will never own another Ford.
Phil if u are not carefull ,, u will be needing a tow truck soon ,, the 6.0 had head gasket probs ,, but Ford says it's not their prob ,, it's Internationals ,, so anyway ,, no one wants to take the blame ,, and no recalls ,, no one got killed or mangled over this ,, sorry ,, but i have 3 customers who have had them ,, now they own Dodges and duramax (sorry DL) ,, one guy bought his 1 ton outta state and had probs on the way home ,, took to local ford dealer and they found ,, yes headgasket probs ,,, Told them they could keep it ,, right there on the spot ,, now he has a new 08 ford f450 ,, so go figure ,, but just MO :)
Our local fire dept. bought a 2007 F-450 cab/chassis with 6.0, for a brush truck. Took it to up-fitter for body. On the way home, head gasket blew. Engine had less than 200 miles on it. They replaced a 1974 GMC with this truck. I KNOW this truck won't last 33 years.
As far as the reprogramming I am talking about, I know it exists.
this customer that bought the f450 has the new 6.2 in it ,, but yes Ken as u say the 6.0 is not worth the time ,, IMO ,, bty the new 6.2 has the automatic cleaning system on it ,, a light comes on ,, and then u pull over and it blows out very very black smoke ,, then u'r goo to go again ,, also ever cked out the tailpipe on the new f450 ,, they have a swirl maker thingy on there ,, it's spose to get the smoke out faster and elemenate the big black cloud when u take off from a stop ,, i bet DL will not own one of these ;) :laugh: :laugh: :laugh: :laugh:
I am SURE DL will pass on a Ford.
We have two 2008 GMC's at the store right now for hitches, salesman told me that they blow black smoke every now and then to clear things caught in exhaust, did not say anything about having to pull over.
msjackie
I told David that if he did not do his rehab I was going to buy him a 6.0 ford so he would have to walk!!!!
love to all
Right now I'm passing on all the NEW EPA friendly diesels. They all seem to have problems with the EPA mandated emission control systems. My beautiful, powerful, sweet smoke smelling "03" Dodge CTD will be paid in full this year. Lordy that means I get a $550/month raise this year. It has 89 K miles on it. Bet it will last another 250 K miles (10 years). It will be a race to the finish. ME vs Big Red) ;) :approve:
Hightower
Thanks for the info, been looking at Dodge's the last day or so, found out that they are even cheaper. Phil
msjackie
HAVE YOU BOTH RECALLED FOR PARTS THEN, RIGHT JK
hope ours will last as long as we do,
I wanted to give our RV a name as soon as we got it, david said wait and the RV will name itself
Shadow
So the EPA mandates a cleaner burning diesel. Making the manufactures come up with mandated emission control systems. Which in turn, blow out clouds of black smoke to clean out the system. :eek: Reducing fuel mileage, causing us to burn more diesel. And so on...... :dead: I'm missing something right
Those clouds of black smoke will give diesel's a black eye AGAIN. :dead: If I bought a new EPA approved diesel, I wouldn't be able to convince any of you how sweet the Dodge Cummins diesel smoke smells. Black smoke clouds :eek: :eek: :bleh:
Hightower
I am taking my truck back to the ford dealer and I am hoping they will check it over good this time. They still say that the the pcm reprogramming is not included on the 6.0 engine. Is there anyway to prove it to him or is it at the dealers option. Man, I hope they can get this thing fixed. Already cost near $600 and I have only had it a month. Phil
OK, I called the dealer that worked on my employees 2003 F-350 with the 6.0 engine.
There is no number that I can give you as far as the reprogramming, but this is what they did.
Recalibrated the PCM
Recalibrated the Transmission Control Module
Recalibrated the FICA Module which is Fuel Injection Control Module
My dealer said if they researched the problem, they would find it. Unfortunatly Ford has thousands of recalibrations for that sorry engine, and a mechanic needs to know what to look for. Good Luck
Hightower
Thanks for all the help, I will pass this on to the dealer. Man, the hoops you have to go through. PHil
