Re: Ford V-10 Horror stories
Phil, I found this on BING. I thought I would share it with all.
Here is a good email from a concerned shop owner:
"As a mechanic shop owner, I am very familiar with this particular Ford problem of spark plugs blowing out of cylinder heads. I own a 2002 F-250 and just yesterday on a perfectly maintained personal truck, I blew the #2 plug while cruising at 60 mph.
I also had never changed plugs due to lower mileage of this truck and therefore cannot be blamed for improper torquing of new plugs or any of the other unique ideas Ford is currently making up. I am somewhat of a Ford person and am not here to bash Ford, however I would like to clarify what happens in this situation. I began to notice what sounded like a fairly loud lifter noise about 5 days prior to blowing a plug and should have been suspicious because this is a overhead cam engine and therefore HAS NO LIFTERS!!!
It does have cam followers that can give trouble but the noise is different. Any way I changed oil at a 2500 mile interval just to be safe and noticed no difference. In hindsight I could have recognized the ticking noise for what it was and maybe saved the spark plug and coil and mostly the threads in the cylinder head. The ticking noise was high pressure air escaping around the threads of the LOOSENED sparkplug!!!
When a plug is loose and an engine is rotating at 2000 rpm, it generates a tremendous amount of pressure each time it fires a cylinder.
So the longer a sparkplug wobbles from being loose in the threads the more thread damage it does and finally the last few good threads can no longer take the pressure and out comes the plug!!, taking the last few threads with it.
So here we are and what do we do now? Most troubling to me is the huge diversity of dollar cost and repair procedures for a relatively simple thing to fix. A thirty dollar HeliCoil kit can do the trick if installed correctly with a good loctite compound installed on the threads of the repair insert. Sadly most mechanics just retap the hole and throw an insert in and a new plug. It usually lasts a while and then blows again creating a bigger problem! Don't panic! IT CAN BE FIXED!!!!
If this happens to you disconnect the coil harness at the plug in question as well as the fuel injector harness and you won't have an engine fire as a result of fuel vapor coming out of the plug hole and being ignited by the exposed coil!!!"
:8ball:
