Fresh Water/Grey water
tommiller1275
What is the best way to add water to fresh water tank and keep grey water tank empty? Do I need a 12 volt water pump to add water? TPM
T.P Miller
Southstl
Hi Titanic, what RV do you have. On most RV's, right next to connection where you connect a hose for the city water, there is a larger cap. You quarter turn it counter clockwise and it opens so the fresh water tank can be filled. Give us bit more information about your unit.
Steve
2001 f250 CC PSD
2002 Montana 5th Wheel
2 minature Dachshunds
http:// www.texasboomers.org
tommiller1275
Sorry I did give enough info. I have a Fleetwood and I find that showers use an extreme amount of water and I empty my grey water often.I want to put together an inexpensive type of 12v water pump to fill my main tank without always having to drain water into the filler tube by hand.Also I need a way to use less water in the shower.I've tried every thing to no great avail.Thanks
T.P Miller
wittmeba
Hello,
Yes the typical gray water tank will fill early. Every little bit of water, drink, ice, brushing teeth with water running, etc that goes down any sink drain and all the shower water go to the gray tank. For whatever reasons, mfgs seem to make most tanks nearly the same size.
I assume that you shower head has an on/off valve right on the handle - not the main hot/cold valves on the wall. We use this all the time to keep showers to a minimum. Get wet/water off at the head/soap/water on at the head/rinse.
You and your guests are the only ones that can change the water usage.
Adding fresh water - you can only fill thru the hole as Southstl indicates. There are ways to assist in getting the water into the tank - small 12Volt pumps, syphon hoses, etc but you need access to potable water.
Bruce & Carolyn Wittmeier
MikeBrandn@aol.com
2001 Ford F250 PSD, Ext cab, Shortbed, Island Blue/Silver, 4X4 Off-road, Auto w/SOF, Alum Wheels, Chrome Step, Line-X bedliner, Reese 16K slider hitch, Jordan Ultima 2020, AirLift Airbags, Sunnybrook 30RKFS
Swede
I am a new RVer and do a fair amount of dry camping, usually near water as I am a trout fisherman. I would like to fill my fresh water tank from the nearby stream. I realize that the water should be filtered. My question is: could I hook up a 12V pump to my water hose, have it attached to a filter near the RV and draw filtered water from the stream into my fresh water tank ?
