front side windows are foggy help!!!
jkill2001
ok i have a 96 bounder and my side windows up front are foggy. i know they are double pane glass so the fog is in between the panes any idea how i can fix this without replacing the glass?
janicenlarry
The seal is broken between the two panes allowing the atmosphere to get into that space which is usually filled with an inert gas. You have no choice except to replace and it aint cheap. :(
jkill2001
yea i got a estimate at the rv dealer i work at and for the window they said anywhere from 400-800 plus 135 installed. but since the rv has to go in for fiberglass work after someone hit it yesterday i don't think i will care
