keeganelectronics
I prepared the following article about GPS. I hope this benefits the reader.
1.0 Basic Description of GPS
The Global Positioning System (GPS) is a satellite-based navigation system made up of a network of 24 satellites placed into orbit by the U.S. Department of Defense. GPS was originally intended for military applications, but in the 1980s, the government made the system available for civilian use. GPS works in any weather conditions, anywhere in the world, 24 hours a day. There are no subscription fees or setup charges to use GPS.
2.0 How GPS works
GPS satellites circle the earth twice a day in a very precise orbit and transmit signal information to earth. GPS receivers take this information and use triangulation to calculate the user's exact location. Essentially, the GPS receiver compares the time a signal was transmitted by a satellite with the time it was received. The time difference tells the GPS receiver how far away the satellite is. Now, with distance measurements from a few more satellites, the receiver can determine the user's position and display it on the unit's electronic map.
A GPS receiver must be locked on to the signal of at least three satellites to calculate a 2D position (latitude and longitude) and track movement. With four or more satellites in view, the receiver can determine the user's 3D position (latitude, longitude and altitude). Once the user's position has been determined, the GPS unit can calculate other information, such as speed, bearing, track, trip distance, distance to destination, sunrise and sunset time and more.
3.0 Who uses GPS
GPS has a variety of applications on land, at sea and in the air. GPS is usable everywhere except where it's impossible to receive the signal such as inside most buildings, in caves and other subterranean locations, and underwater. The most common airborne applications are for navigation by general aviation and commercial aircraft. At sea, GPS is also typically used for navigation by recreational boaters, commercial fishermen, and professional mariners. Land-based applications are more diverse. The scientific community uses GPS for its precision timing capability and position information.
Surveyors use GPS for an increasing portion of their work. GPS offers cost savings by drastically reducing setup time at the survey site and providing incredible accuracy. Basic survey units, costing thousands of dollars, can offer accuracies down to one meter. More expensive systems are available that can provide accuracies to within a centimeter.
Recreational uses of GPS are almost as varied as the number of recreational sports available. GPS is popular among hikers, hunters, snowmobilers, mountain bikers, and cross-country skiers, just to name a few. Anyone who needs to keep track of where he or she is, to find his or her way to a specified location, or know what direction and how fast he or she is going can utilize the benefits of the global positioning system.
GPS is now commonplace in automobiles as well. Some basic systems are in place and provide emergency roadside assistance at the push of a button (by transmitting your current position to a dispatch center). More sophisticated systems that show your position on a street map are also available. Currently these systems allow a driver to keep track of where he or she is and suggest the best route to follow to reach a designated location.
GPS is also used by outdoorsmen to hunt treasure. This fun outdoor adventure is called Geocaching. Geocaching is a widely popular, high-tech game of treasure hunting.
Geocachers seek out hidden treasures utilizing GPS coordinates posted on the Internet by those hiding the cache. Using a GPS unit, they then trek out into the backwoods or urban jungles to find the hiding spot of the cache. Once found, a cache may provide the visitor with a wide variety of rewards. If the visitor takes something out of the cache, they are asked to leave something in return. For some, the biggest reward is the thrill of the search and the discovery of a place that they have never been.
4.0 What is WAAS
WAAS stands for Wide Area Augmentation System. This system of satellites and ground stations provide GPS signal corrections resulting in better position accuracy. An average of five times better accuracy is achieved using WAAS. A WAAS capable receiver can give a position accuracy of better than three meters 95 percent of the time. Additional receiving equipment or pay service fees to utilize WAAS is not necessary.
5.0 The Origins of WAAS
The Federal Aviation Administration (FAA) and the Department of Transportation (DOT) are developing the WAAS program for use in precision flight approaches. Currently, GPS alone does not meet the FAA's navigation requirements for accuracy, integrity, and availability. WAAS corrects for GPS signal errors caused by ionospheric disturbances, timing, and satellite orbit errors, and it provides vital integrity information regarding the health of each GPS satellite.
6.0 How WAAS Works
WAAS consists of approximately 25 ground reference stations positioned across the United States that monitor GPS satellite data. Two master stations, located on either coast, collect data from the reference stations and create a GPS correction message. This correction accounts for GPS satellite orbit and clock drift plus signal delays caused by the atmosphere and ionosphere. The corrected differential message is then broadcast through one of two geostationary satellites, or satellites with a fixed position over the equator. The information is compatible with the basic GPS signal structure, hence, any WAAS-enabled GPS receiver can read the signal.
7.0 Who Benefits from WAAS
Currently, WAAS satellite coverage is only available in North America. There are no ground reference stations in South America, so even though GPS users there can receive WAAS, the signal has not been corrected and thus would not improve the accuracy of their unit. For some users in the U.S., the position of the satellites over the equator makes it difficult to receive the signals when trees or mountains obstruct the view of the horizon. WAAS signal reception is ideal for open land and marine applications.
WAAS provides extended coverage both inland and offshore compared to the land-based DGPS (differential GPS) system. Another benefit of WAAS is that it does not require additional receiving equipment, while DGPS does.
Other governments are developing similar satellite-based differential systems. In Asia, it's the Japanese Multi-Functional Satellite Augmentation System (MSAS), while Europe has the Euro Geostationary Navigation Overlay Service (EGNOS). Eventually, GPS users around the world will have access to precise position data using these and other compatible systems.
Please contact me at sales@keeganelectronics.com if there are any questions about GPS or interest in information about Garmin GPS & Navigation systems.
2.0 How GPS works
3.0 Who uses GPS
4.0 What is WAAS
6.0 How WAAS Works
