Graywater smells worse than Blackwater...
mykidsdaddy
Why??? My boss and I were talking about this and couldn't come up with a sound reason! I think it may be from all the different micro-organisms, yeast inparticular, that we have in our mouths (from tooth brushing) mixing with nutrient rich water from the kitchen sink. I'm thinking the water in the gray tank is "brewing" up something nasty!
Any other ideas???
Triple E
Re: Graywater smells worse than Blackwater...
You might try filling up your gray tank with about 3 cups of bleach and a full tank of fresh water, let it sit over night. This has worked for me. I will also pour a cup of Lysol into the tank about once a month. Good luck.
The reason is probably the fact that you put many types of grease into the gray tank which tend to coat things and most do not treat the gray water either. We actually do not treat black water as fulltimers, but we do at times address the gray. Grease when it becomes rancid will become very odoriferous in a fairly short time in hot weather. It is really quite normal and very common for it to smell worse than the black because the black has more natural tendency to break down.
I would never put bleach or such things into the waste tanks. While that will stop any odor for a short time, it does so by destroying all of the helpful bacteria that causes the contaminates in your tank to break down into liquids so that they will be easily emptied out. In addition, should you put a large enough amount to actually do much, it can also cause problems in septic systems which are very common in RV parks. With bleach it also depends upon the size of your waste tank just how much would be required to do anything, but even if it helps, the rancid residue will remain, it just won't smell for a while.
A much better approach is to use one of the bacterial products to treat your gray water with from time to time for that same purpose. We also use a mix of either dishwasher detergent or laundry detergent and water in our tanks just before travel a couple of times per year to remove any residue that has built up in them.
WandaLust
Member
Kirk - 7/3/2009 2:35 We also use a mix of either dishwasher detergent or laundry detergent and water in our tanks just before travel a couple of times per year to remove any residue that has built up in them.
But that wouldn't stay in the lines long enough to clean them though it would probably work in the tank itself. How do you sanitize the drain pipe down to the graywater tank? Smelly scum would remain to produce the odor of rancid grease although the tank was clean. If there's a regular trap, the odor from the tank shouldn't be entering the cabin. If it smells when "dumping"... who cares? ;)
