F felipeferdinand New Member Apr 6, 2020 #1 my freedom express pilot trailer heater not working it just blows air then shutdown when u moved the thermostat, please help, thanks .
F felipeferdinand New Member Apr 7, 2020 #2 i called a tech n he said it might be a board problem costing me $800 good luck to yours.
J Jack Hall New Member May 15, 2021 #3 Unless you have some sort of strange heater, $800 for a board is crazy expensive. Tighten the connections in the thermostat. That solved my problem in less than 30 minutes for ZERO dollars.
