Brenda Jenkins
We have a Sandpiper REBH 2017 5th and we wanted to know if the heat is supposed to come from the vents in the floor or from where the a/c air comes from? If it comes from the floor how do I get it to do it? Thanks!
We don't know where the furnace is. Could you please tell us?Brenda the heat should come from floor vents. Will your furnace light?
We do have dual thermostats but we can't figure out how to set them. Ant advice or guidance would be greatly appreciated!You should have a thermostat on the wall that switches from ac to heat. Set to heat and raise temp till furnace lights.
Brenda do you mean the furnace itself or the control for it? As far as the furnace look on outside for the vent from furnace and the furnace will be right there. If you are hunting the control it should be on an interior wall. If your AC has a wall thermostat it may also serve the furnace. On the thermostat press the mode till furnace is displayed. Not sure yours is this way but being a 2017 5th wheel I would think it would. Did you buy new? If so the sale person should have walked you through all this. How far are you from dealer. If near go back and have them show you on another unit.
Brenda, be sure to run the temp up high enough to get the furnace to ignite. Do you hear any clicking when you try the furnace? You should. Hard to say where the burner is located. Mine on the motor home is under the fridge. Will your stove light? Is your battery charged?
