HELP PLEASE
should be automatic light when you turn it on. Turn on your stove burner to purge the lines of air. You should hear a clicking from the furnace if the auto light is working. Does the fan come on? Welcome to the forum
jaynjazz
Junior Member
Hi There.
I know our lines need to purge a little (a minute or so) before the furnace, water heater or stove will work. Once they are purged all those should be automatic. You may be able to go outside and light it manually.
Good Luck!
Mike in TO
Hi, new member here. Just got our 2015 Outback last fall and didn’t use it till spring, so we didn’t have the need to heat it by furnace. We read the manual but can’t find the thermostat. Just the remote. Where is the thermostat kept? It’s not obvious. Also read that it ignites automatically, is that true? We are boondocking with power from a solar- battery set up, does that matter? All lights are operating off the battery.
Thanks for any help/ suggestions.
