The fridge should work on propane while not hooked to shore power. Some are 3 way and will run off battery power 12 volt also. Would guess yours most likely propane and 120 volt. The engine ac or dash will work while driving down road but has hard time cooling because you have large area. If you have generator you can run roof air off it. If air is not flowing out of vents either fan is not working or you have a vacuum or control problem. May also be out of freon. Hard to say not having the unit to check. Good luck. Take one thing at a time and you will figure it out. Dont be afraid to ask campers at camp grounds. With this virus is a bad time for other campers to help
