Re: How does Coachmen monitor panel work?
That's just it...I don't even know where the switch/switches are. There are no rocker style switches. If there are any switches there they are the style you would find on your microwave because the panel is completely flat. There are rectangles that could be vertical bar graphs or buttons that are about the size of your thumb from the first knuckle. These are marked Gray 1, Gray 2, Holding, Batt, LP and one for the fresh water. There is also a horizontal bar well above these marked "Batt" with I believe 5 LEDS that seem to indicate battery strength. Nothing happens when you push on any of the rectangles. They don't even feel like they "give" when you push on them. Again, I know there is good DC and Gnd at the panel. There's also a globe emblem in the upper left corner above the pump switch. I know the panel was manufactured by KIB Enterprises and I have an email to their service dept but haven't heard back yet (it's only been a day). Please keep the thoughts, ideas, experiences and advice coming. Thanks for responding!
