Dog-Father
Junior Member
I'm having intermittent starting problems with my GM van based RV. It has the 5.7L V8 w/EFI, with 55K miles on it.
The starter motor was first replaced in 2003, just after I bought the RV used. Then it went bad again in 2005. This time, the starter and ignition switch was replaced with new AC Delco parts, to be sure they would last a while.
At least, I paid extra to get new parts. So, I hope that new AC parts were used in the repair.
The alternator was replaced a few yrs back as well, and the dash guage shows the alternator to be
working fine.
The RV seems to have plenty of battery power to start, but when you turn the key, it like tries to
turnover but can't. After a while, if you keep trying it will start.
This problem is getting worse and I feel I can no longer trust my RV to start.
I had this same problem about 6 months ago and the battery was replaced. This did fix the problem, at least for a while. But my RV is doing about the same thing again now.
I did not leave the lights on, and I did not find any drain, on the electrical system. I have not used it a
lot since the battery was replaced, but enough to keep the battery charged. In other words, it has not
just been sitting, unused for a long period of time. I go some place at least twice a week.
It has been fairly cool here in FL, the last couple of weeks. Most of my trips are less than 15 miles. So, I would not think heat (affecting the starter motor) is the problem, or a part of the problem. Unless during the summer, some damage took place, and it is now just showing up.
My understand is that GM tends to have problems with heat, from an exhaust pipe damaging the starter
or solenoid. I just doubt this is the cause of the problem. I have a feeling it's a problem in the
steering column, like the ignition switch, but no way to be sure.
Any ideas on what the problem might be, or how to fix it, once and for all.
Doug FL
working fine.
Doug FL
