RE: Kohler Generator Air Filter
Hi Scott
I don’t think anyone can say with any degree of certainty how long anything will run.
I will all depend on what kind of maintenance it has received
, and how was it treated :dead: . Was it started, allowed to worm up before loading
, was it overloaded?
Was it allowed run without load before shutting down.
I don’t know much about small gas generators :bleh: . But it is a gas motor, so it should be about the same as a car.
Is it using oil? :question:
How hard is it to start? :question:
Look at the exhaust, if it white you are burning oil, black running too rich ( air/fuel mix is bad)
Can you run a compression test? That will tell you a lot :approve:
Maybe the second poster can get you information on what the Cylinder pressure :approve: should be for a compression test. For a car is it around 180 PSI. :approve: But that depends on make & model
Hope this helps
:clown: :shy: :approve: :approve:
