Re: light up the outer lights
Hello and welcome to the forum.
The simplest way is to jump wires at the front plug. Look at your plug....put the "key" at the top....at 11:00, you have the Charge terminal....At 1:00, you have the marker light terminal....At 3:00 and 9:00, you have your brake light (signal) terminals. If you take 3 wires and jump from the charge terminal to the other 3, and all you lights will be on. Be careful, you will add a LOT of draw on your battery which will put your converter (charger) on overload. Good chance of shortening it's life.
