tithingman
I have 2007 four winds magellan class A and I can't go from park to drive. Will work if switch of and go to neutral then drive. Help
Triple E - 2/16/2011 8:03 PM Your brake has to be applied to go from Park to any gear. I would check the switch that indicates that the brakes are being applied. Should be somewhere around the brake pedal or brake linkage. Are you brakes light working?
There may also be a linkage that release's the transmission, not sure. But that where I would start. The Brake Pedal.
Good Luck.
