Low point drain
JPG
I have a 2018 Grand Design Reflection and I want to change the plugs on the low point drain to ball valves. I’m not sure what size the pex tubing is, it doesn’t feel like 1/2 inch, was wondering if anyone knew the correct size of the 2 tubes.
Thank you
Thank you
Exams are starting soon and I will definitely use this service because this service - https://nocramming.com/tutoring/italki - can help with any exam paper! This service has helped me a lot in the past and that's why I trust this service. This site can also write any academic paper, and that's why I use it myself.
I’ve got a similar model—those low point drain lines are usually 3/8" PEX, not 1/2". It throws a lot of people off because of the fittings. You can always double-check with a caliper if you want to be sure, but 3/8" is likely what you’re working with. Ball valves make a big difference, by the way—nice upgrade.
Back
