M/H leveling system
Working on a M/H with the HWH 200 series lever controlled system. When you hit the on button the red light comes on which tells you the brake is not applied or the trans is not in park. Brake is applied and trans is in park. Checked emergency brake switch and it's hooked up. Anyone know how these systems hook to the brake and trans.? Thanks
Chelse L. Nash
fulltimer03@yahoo.com
rv wizard
M/H leveling system
If the Feet are not fully retracted or the switch that senses the feet is bad that light may also stay on. I would think that it may have wiring for the brake switch and park switch of transmission. My systems have always been the Quadra Big Foot. Hope you can find the answer your looking for. Good luck & enjoy.
Mike, Amy, Ashley, Candi
2000 Gulf Stream Scenic Crusier on Spartan M.M. 330 hp. 6 spd. Allison
#3 & #8 NASCAR
M/H leveling system
Problem solved. The emergency brake warning switch was bad. Found a wiring diagram and it really helped in figuring out how the system works.
Chelse L. Nash
