Monitor Panel Lights not working
freelander
I was filling my fresh water tank checking all the lites on the panel all were working, when finished all lites on the panel would not come on except the water pump green lite, the red hot water lite was working and quit.. what would be the first steps in trouble shooting.. had shore power on at the time, coach battery was charging and full, did not see any blown fuses... also the stove hood fan and lite went out about the same time ??? maybe related ??
2005 coachman freelander 2400 model...
RV Trax
Re: Monitor Panel Lights not working
Coach/House 12 volt supply fuses, connections and grounds should be tested first.
akjimny
Hi Woody and welcome to the RVUSA Forum. Sounds like a main fuse somewhere on your power converter. Are you still getting 13+ volts to the batteries when plugged into shore power?
as Jim said ck that first ,, i have a feeling u might have a converter going bad ,, how does all the rest of the 12 volt stuff act ??? :)
