New owner
Ok, I won't pester you any more for a while, this should be enough to digest for a while
Hey, Guy Archer's suggestion for a note book is a great one (I suffer from CRS)as most travelers have one on board. We use one with dividers in spiral binder then tuck it away in a loose leaf binder, that way pages don't disappear unless you want them too.
On the dividers ours are separated as follows: Section 1 for things to do when I get home before the next trip, things I need to buy, fix or what have you and also ideas on what I need to have to make my trips more enjoyable. Section 2 is my mechanical history, on oil changes fuel milage checks and most importantly part numbers on filters, plugs belts, type oil engine specifications such as timing . Just the good quick reference section you think you may need.
(OH I FORGOT the things you need to include in your motor home Stash a set of fan belts, couple bottles of extra oil, trans and brake fluid, it may come in handy on the road in the middle of nowhere and they won't spoil.) Section 3 is for the Precious Lady to write down things she needs to remember to bring to make things smoother and also that is where she has her trip plans on where to stop, etc. The last section is out trip diary again because I have CRS. It is nice to look back months later and see what you did and whether you might change things somewhat if you made the same trip again.
As fars as planning trips, we use Rand Mc Nally's online plan a trip guide which can be found at RandMcanally.com. As far as the camp grounds there is a campground directory put out by Trailer Life and also Woodall's, cost about 20 bucks but worth the money.
Hope this helps out some.
