I just got my first used rv, it is still in the winterized mode. But I have been checking things to make sure everything works right.
Finally got a 30amp service so I can plug it in at home, the refrigerator works while on 110, have not tried the lp (do I have to light the pilot light or will it do it on its own ?) The lp furnace works, while on the generator and on 110, (should this run while on 12v also ? ) The air conditioner works on both generator and 110.
Now, here is my problem - - with the generator OFF and the engine motor OFF, nothing works - no overhead lights (what else should be working off the auxiliary battery ??)
On the dash by the drivers seat is a 12v Master Switch, it cuts the circuit between the auxiliary battery and the 12v fuse panel - I have tried it in both positions and there is no change - I do not know which is on or off (not labeled). If this switch is off when the unit is on 110, the converter will not charge to auxiliary battery.
Anybody have any ideas what might be wrong with the 12v system ??
Also in the kitchen there is a "monitor panel" on the left it gives the water tanks quanity of water, I understand this part. But on the right side it says "battery" (on the bottom) and above that are 4 lights, labeled "C" showing green "G" showing yellow "F" showing red & "L" showing red. What do these letters stand for and the coralating colored lights ??
Hoping to de-winterize it this week end and then I will probably have more questions about the water part of the rv.
The RV i bought is a 1993 Jayco 280 Eagle Series, 28 ft with a ford F350 chassis.
Thanks,
Margaret
Thanks,
Margaret
