Newbie with questions
Carbine15
We just bought our first RV. A 2001 Trail Harbor 5th wheel. I have several questions but will ask the most pressing one now. I tried to raise my landing gear but forgot to pull the saftey pins. Now I can't pull the pins so I can't raise or lower the trailer. Any help would be appreciated. Thanks. Tim
Tim will they not run back down so you can remove the pin. probably have to get it just right to remove pressure.
Carbine15
I actually had to pull the truck under the 5th wheel and jack it up to lift the trailer enough to relieve the pressure.
Thanks for the reply on how you got it Carbine15. May help someone else. Glad you got it
