Hi Everyone;
My name is Bob, we just bought a 1989 Pace Arrow Fleetwood Class A 32 feet. It only has 12K on it.
We bought this because 2 of the 5 kids race motocross and I will not sleep in a tent at the track anymore. I know its old, but it was really cheap. It needs some work and I have a ton of questions. We will be using this for racing and pulling the bike trailer.
A) I cannot open the fridge, it smells like amonia, why? Can this be fixed easily and cheaply.
B) The gas gage is stuck on 1/2 a tank. Will this cause the generator not to run. It will crank over but not run.
It will run if I spray carb cleaner in the carb. I can keep it running.
C) The roof top AC's will not come one no matter what position I put the switch in the cabinet on.
D) There are 3 batteries 2 6volt and 1 12. Iknow the 12 volt is for the engine. When I plug the camper into the house is it
suppose to charge all 3 or just the 2 6volts.
E) I want to seal the roof seams but what is the product that I should use?
F) The inside lights on the left side by the couch and table don't work and just keep blowing the fuses, any ideas. I know there is
a short but any ideas on where to start.
G) I put 7 gallons of anti-freeze in the water tank and ran it through the system. All of the faucets come out nice and red, but the
hot water ones are pink. How do I know if there is enought in the water heater and how do you drain it.
H) What else should I be doing or looking for to make sure this thing up to par, as we will be traveling aroung New England
and the East Coast racing starting in the spring, and with 7 of us plus taking care of the bikes I don't want to worry about
this thing.
I) Is there a good source for used parts that I won't be ripped off on, and should I stay away from ebay.
J) I don't want to start anything, but what is the best way to sterilize the water tanks (all).
K) Is it not a good idea to drink the water out of the faucet? I don't mind brining bottled water if I have to, but would like not to
if its ok.
Thank-You All
Bob
this thing.
if its ok.
Thank-You All
Bob
