I have the same problem, my converter (WFCO 45a ) doesen't seem to have a breaker. It does have two 30a fuses. A little history first. About a month ago I started up my generater and turned on the AC and tried the outlets, NO 120v POWER, after resetting the gen breaker still no power. I then found two 30a fuses on the converter box, both were blown. I replaced them and everything worked, I kept checking the converter box and it did get a little warm but nothing to alarm me. Fast forward to yesterday. I started the gen, NO 120v POWER. The gen breaker was reset, checked all fuses in the breaker box and on the converter box, all are ok, reset all GFCI outlets, still no power. Could I have another breaker I don't know about or is my converter shot? My converter box and breaker box are under the sofa. Also, I have 120v power with the shore cable plugged in and the converter box seems to be working then because the fan runs ( the fan does not run when trying to use gen power).
Kenneth
