The last two trips I've had a problem with the fridge staying cold the whole time. I fire up the propane the day before we leave and it is around 40 degrees when we are ready to go (overnight). I drive to the campground(s) (3 1/2 hrs and 1/2 hr trips) and the temp goes up. I level the unit and let it sit and the temp still is high (~4hrs). I switch to electric, which never seems to cool properly from day one about 3 years ago now, and it gets cool but not enough (over night). I switch back to propane and in a few hours it is at 40 again. There isn't a complete pattern of when it does this.
I know: has to be level, it has worked properly for two years and two trips so this issue is recent (last two trips), may need to pull and clean, burner and jet, and the temp feeler by the burner is worn/burnt at the tip.
Any ideas??
Thanks,
Steve
Any ideas??
Thanks,
Steve
