Gary, I’m picking up where I left off from the Fall.
The thermostat kicked on the blower but the pilot wouldn’t light.
Removed, inspected and replaced pilot assembly but now blower doesn’t work. Cleaned combustion chamber also.
Bought a few $2.15 screwy looking fuses, replaced fuse, now both work.
Blower on…Pilot on… but main burner will not ignite???
After reading the manual for over an hour and remembering how the blower sounded I either have:
Junk in blower or air combustion chamber causing lack of airflow to open switch and allow burner to fire.
Airflow switch is dirty causing poor opening and closing.
Airflow switch is bad.
Are the both posts, that receive the thermostat wiring, on the control valve energized when trying to ignite the main burner? My friend seemed to think they should be and that a relay was bad but from what I read, I think I ruled out both relays.
If anyone has any thoughts… fire away. Talk about on the job training.
sp
sp
