mikey1000rr
Junior Member
gen is a 5500 gold on a 2006 toy hauler . I just got the rig old owner said it sat since about 2009 so I changed the air filter cleaned plugs new fuel cleaned carb the best I could with carb cleaner and 4c spray . Gen did fire up but idle is everywhere runs for either a few seconds or few minutes and quits with code 14,15 or 37 but if I pinch the fuel line gen stays on as long as I pinch and release for a couple of seconds and pinch again it will stay on as long as I do that . also I think the old owner tried firing it up when he had it and looks like he ended moving the spring from the notch it originally sat in ( I believe the one that hooks to the throttle and the lever coming from the engine) any help would really be appreciated
