flwamplers
We just purchased our first our first RV about 2 months ago, its a 96 Itasca Suncruiser with very low miles on it (17k), and only 100hrs on the generator. As you could expect, the generator is a little quirky. Here are some of the issues and countermeasures I have done:
1. Under load, it was searching: Cleaned plugs and carb: seems much better now.
2. Microwave shuts off: noted that voltage is running approximately 130 and then drops to 120 while microwave runs...and then it shuts off. I have adjusted the low idle up, which helped, but now it shuts down really hard.
3. A lot of oil blow by: I have oil leaking out of the breather...when I opened the breather box, the filter was saturated with oil on the bottom and so was the box. I ran it without the filter on and I could see the oil blowing back. No resolution yet.
Any thoughts and recommendations would be much appreciated!
Bradley
Bradley
