ONAN Generator Performance
There is a possibility that the air cleaner is dirty or the carb. is set too lean. Either condition is one cause of governor hunting. Check the generator exhaust to see if it is producing a black smoke, this would indicate too rich a mixture. Adjust the carb. mixture, or maybe the air filter is dirty and causing a rich mixture. If the carb. is adjustable, turn the mixture screw counterclockwise to make it real rich. This will cause even more black exhaust smoke and more hunting. Then slowly turn it in clockwise until the engine runs steady. If the engine sounds strong, but has an regular stumbling, you might want to replace the spark plug. Other than that, you will have to take it to a small engine shop. It should run very steady either at full load or unloaded. Hope this helps.
