onthebrink
Hi all,
The Mrs and I recently purchased a repo'd 1999 Mountain Aire (gas) motorhome. Everything on it works great with the exception of the Onan Marquise BGM 5500 generator with 169 hours. When purchased the gen would not start. Found the spark plugs in bad shape, a fuel line leak, and oil in need of a change. The unit looked like someone just changed the fuel filter and maybe cleaned the slip rings in a quick attempt to get it working. After changing the plugs, oil, and correcting the fuel line leak the unit starts fine. It will run fine under a small load (tv) but shuts down under a heavy load. (ac or microwave)
Cleaned carb with Gumout carb spray and problem persists.
What I found is the gen puts out a steady 125v while not loaded or a small load. Note that I'm using an inexpensive walmart multi-meter, true voltage may vary. When I put the generator under load the generator sounds like it is slowing under the load and the voltage drops to about 110v. After about 30 seconds the generator shuts itself down.
As an experiment I manually increased the throttle with multi-meter on an exterior outlet while the unit was under load and found I can bring the voltage back to 125v and it will not shut down. (ran microwave for one minute)
So my question is; Am I right to assume the unit is not responding to a load change and what would cause the gen not to respond?
Thanks in advance,
Jim
Thanks in advance,
Jim
