Re: OPINION ON BUYING 2001 HOLIDAY RAMBLER
I have a 2000 with a Cat same trans and the freightliner. Endeavor is equal to monaco Diplomat both mid range solid RV's. Inspection is the key, find out just what you are buying. The motor most likely has 70000 on it(low mileage) tires are either getting old or have been replaced, batteries could be original but most likely newer, gen should have around 500 hours(the 7500 will go 10000). I have just gotten done on mine with a two year replace all the fluids(all) and filters plus air dryer. Endeavors are a well equipped MH and have a lot of systems to check out. Having had an A before you know it is a continual finding little thing and keeping up on them.
