I'm thinking of installing an inverter in my class C mostly in order to run smaller AC appliances while underway or boondocking. I seem to recall reading somewhere that there are ways to run the fridge's AC power connection through an inverter, so you have the option of running the fridge on inverter-generated AC power instead of propane while underway.
How and where do you do this? Most inverters are a box with an on/off switch and a few AC outlets on the front. On my rig the fridge's AC power connection is difficut to access.
- Given the access issues, do you have to dedicate an inverter to the fridge if you go this route, or can you realistically use the same inverter for the fridge and other loads?
- Do you configure the fridge so that it always gets its AC via the inverter, or can you switch between inverter AC and generator/shore power sources?
Thanks.
Thanks.
