dolphin2760
I have a problem with the Chevy 454 engine in a 1988 Dolphin 2760 Class A motor home. After installing new plugs, plug wires, rotor, cap, a loud explosion is heard in the exhaust system upon shutdown, and when the gas pedal is advanced almost fully, the engine suddenly loses power and it sounds like the engine is gasping for air. The engine also will often not shut down when the ignition is turned off, and sounds like it is diseling. The only way I can shut down the engine, and this is really bizarre, is to pull out the headlight switch.
Rodney Stich stich@unfriendlyskies.com
