Pancanbob;74645 said:
I Agree with TexasClodhopper :stupid:
He should just post his questions...
I get too much spam as it is
Take care
Hi there,
Understand your reluctance to share email details however there are 25 questions on the sheet so I think it may be too awkward to post here. All I can say is that you can rest assured your email adress will be treated in complete confidence and I will not share nor distribute to any third party.
If anyone can suggest an alternative way to share this xls spreadsheet I'd like to hear it.
That said I have cut and pasted the 'PAPER COPY' I have below.....maybe this could help?? Thanks in advance toi any one who helps.
Thank you for completing this questionaire. Please answer each question on the left.
Please select one option
1 How old is your Motorhome/Caravan (in years). Upto 5 Upto 10 Upto 15 Upto 20
2 Would you say levelling your vehicle is easy when arriving at a campsite? YES NO
3 How long, on average would you spend 'levelling' your Motorhome/Caravan (in Minutes) Less than 5 Less than 10 Less than 20 More than 20
4 What would you consider to be the most problematic when levelling your vehicle? Lack of Indication Reliable Indication Both
5 Does your vehicle have an automatic 'self levelling' system? YES NO
6 Does your vehicle have a level indicator? YES NO
7 If your vehicle has a level indicator:
What type is it Plastic, twin Bubble 'T' type. Integrated into vehicle Electronic,hand held.
Would you say it's reliable, fit for purpose? YES NO
Would you say it is easy to use? YES NO
8 If a system was available to assist you in levelling your vehicle:
What indications would you hold most beneficial? Visual Audible Both
What functions would you require from it? Indication only Indication plus Powered levelling Automatic Powered Levelling
What would you be prepared to pay for a DIY kit (with full instructions)? Less than £10 Less than £25 Less than £50 Less than £100 More than £100
9 When your vehicle is not in use, do you isolate your battery to preserve it? YES NO
10 If your vehicle has a clock, does it remember the time/date if you disconnect the battery? YES NO
11 If no, how difficult would you say it is to reprogramed it? EASY HARD Never bother to correct it
12 Would you say a clock, integrated into your vehicle which automatically reprograms to the correct time after a period of no power is…… A good idea A Bad Idea Desirable
13 If so, what would you be prepared to pay for a DIY Kit (with full instructions) Less than £10 Less than £25 Less than £50 Less than £100 More than £100
14 If you own a caravan, do you find it easy to reverse into a confined space? YES NO N/A
15 If you own a motorhome, do you find it easy to reverse into a confined space? YES NO N/A
16 Does your motorhome have reverse parking aids? YES NO N/A
17 Does your caravan have reverse parking aids? YES NO N/A
18 If yes. What type? Beeper Beeper/Indicator Camera
19 If no, what would you say is most desirable? Beeper Beeper/Indicator Camera
20 If your vehicle has parking aids, what areas are assisted? Rear Only Rear and Sides Rear, Sides and overhead
21 What area would you say is most desirable to be assisted? Rear Only Rear and Sides Rear, Sides and overhead
22 If your vehicle does not have parking aids, have you considered fitting a system? NO YES, Too Expensive Yes, Too difficult
23 What would you be prepared to pay for a DIY kit with:
Audio indications only Less than £10 Less than £25 Less than £50 Less than £100 More than £100
Audible and visual Indications Less than £10 Less than £25 Less than £50 Less than £100 More than £100
Real Time Video imagery Less than £10 Less than £25 Less than £50 Less than £100 More than £100
24 Are there any other services/problems you would like to see available to buy off the shelf? If so, please comment.
25
26 If a product was available which combined all 3 of the above services in a DIY kit, would you buy it? If so, what would you consider a fair price? Yes, up to £50 Yes, up to £75 Yes, up to £100 Yes, over £100 No
27 You vehicle details, optional.
