Folks I have a 2005 Georgie Boy Pursuit and the rear slide wont go out. It has a small panel with a center select switch and the front and rear slide switches. The front works ok and when I hit the rear slide button I hear a relay click but then nothing. If I push hard and wiggle sometimes it will start to go out. I figure I either have a bad switch or a bad relay. What I can't figure out is how to pop off the switch plate to access the switches. It appears that the plastic cover should just pop off as there are no set screws etc holding it in place. When I try I get a bit worried as it feel like I am pulling the whole switch assembly off of the wall.
Any clues as to the source of my problem or how to take off the switch cover?
