RESET SWITCH
EDEDED
HAVE 2008 HR, IS THERE A RESET SWITCH FOR THE BATTERY CUTOFF AT THE ENTRY DOOR?
OR WILL I HAVE TO HAVE IT SERVICED
THANK YOU
ED
Re: RESET SWITCH
Welcome to the forum Ed. Mine has a on and off switch at the door Need more inf? I really don't understand what you are asking. Is there so kind of problem?
Re: RESET SWITCH
Most battery isolators have either a rocker switch, or two push buttons. The most common are from Intelitec and use the rocker switch that is spring returned. Mine if you push it up it goes to the closed condition and down opens it. The switch is normally in the center position.
