Roof Sealant
Shoulder
I need to seal the roof on my 1989 Pace Arrow.
I don't know what to use and where to get it.
Could someone please give me the name or brand and what to get. I really need to seal this before the winter gets here!!!
Thank-You
Bob
ironart
Re: Roof Sealant
Hi Shoulder,
You might want to take a look at "RV Tips and Tricks" under post "Roof Caulk/Sealant" Good Info...?
Shoulder
RE: Roof Sealant
"You might want to take a look at "RV Tips and Tricks" under post "Roof Caulk/Sealant" Good Info...?"
I looked there Thank-you.
Everything seems to be about AL. or Rubber roofs. My roof seems to be fiberglass.
The previous owner had sealed it but its all cracked and leaking pretty bad. Both sides of the roof.
I will have to seal both sides for the full length (36')
I don't know what to use, and I don't want to have to do it twice.
Bob
ironart
Re: Roof Sealant
Hi Bob......Good roof sealant (self leveling Byutel) will work on your fiberglass roof.....The Eternabond tape will probably be the best but is expensive...
Just don't use silicone as it probably won't stick to what you have now......Be sure the surface has been cleaned well before you start....
Shoulder
RE: Roof Sealant
"Good roof sealant (self leveling Byutel) will work on your fiberglass roof.....The Eternabond tape will probably be the best but is expensive... "
Thank-You for the help!!!!! Do you know where I can buy this at. Besides an RV place or do I have to get it there?
Thank-You
Bob
vanole
Re: Roof Sealant
Once again not to step on ironart toes I used these folk in the past and they were the cheapest around at the time http://www.bestmaterials.com/default.aspx
Shoulder you are spot on concerning "RV place" Find a roofer etc who sells the stuff frequently ad it should be cheaper. Notice the different widths of the tape when you get out on the site. Much more of a selection than you will find at an RV dealer or camping world.
V/R
Jeff
Easiest way to eternabond is product tab a top of page "SORRY!!!"
dggreer
Re: Roof Sealant
Byutel is a good sealant but 11 years ago I used polyurathane made by vulkem on my 1990 southwind and when I traded it in last sept the sealant was still plyable had no cracks and no leaks. It is similar to what they use to hold in wind sheilds but differnt in formula. My neighbor and my self used it to cauk our houses 25 years ago and never had to recauk since. If used be careful not to use under vents or AC's or any thing you might have to remove because it is as good as an adhesive as a sealer. Just draw a bead with it and put your hands in soapey water and smooth out or shape any way you want. I talked the railroad into useing it on signal box doors years ago but had to quit because the door had to be cut off because the sealer would not let go. :dead:
JoshB
I advise a polyurethane adhesive; it is flexible, waterproof, paintable and strong. Brands of this include:
  • Bostik ISR
  • Sikaflex
  • Henkel MS
Good for fibreglass and pre-coated aluminium.
