RV Curtain Installation Tips for a Cozy and Functional Space
ttstt
Member
Traveling in an RV offers comfort, mobility, and the freedom to make the road your home. But when it comes to privacy, light control, and aesthetics, curtains are more than just decoration—they're essential. Whether you're replacing worn-out panels or outfitting a new van build, this guide will walk you through key RV curtain installation tips for success.
1. Measure Precisely—Twice
Unlike standard homes, RV windows vary in shape and size, often featuring rounded corners, shallow depths, or non-standard angles. Use a flexible measuring tape to:
  • Measure the window width (add 2–3 inches for overlap)
  • Measure from top of the mount to the bottom of the window
  • Account for whether you want floor-length or just window coverage
For best results, always double-check measurements before purchasing or cutting fabric.
2. Choose the Right Mounting Hardware
Space is tight in an RV, so traditional curtain rods may not work. Instead, consider:
  • Tension rods: Great for no-drill installs
  • Ceiling or wall-mount brackets: Ideal for small alcoves
  • Velcro or snaps: Best for privacy curtains or curved walls
Need ideas? Check out our guide to hanging curtains without drilling for RV-friendly hardware solutions.
3. Use Lightweight, Durable Fabrics
Your curtains need to stay in place while driving, so avoid heavy, swinging materials. Go for:
  • Polyester or cotton blends: Light and washable
  • Blackout-lined fabrics: Great for temperature and light control
  • Thermal or UV-blocking curtains: Ideal for windows facing sun exposure
Explore our RV-ready curtain styles designed for durability and road-friendly function.
4. Secure Everything
Driving vibrations and wind can shift even the best-mounted curtains. Use:
  • Curtain holdbacks or straps to keep fabric tight during motion
  • Magnetic or snap closures for privacy curtains
  • Hook-and-loop tape (Velcro) for cab separators
5. Don’t Forget Vent and Door Curtains
Small details matter—add curtains or covers for:
  • Rear windows or entry doors
  • Skylights or bathroom vents
  • Cab dividers for sleeping privacy
These finishing touches make your RV feel like a true home on wheels.
Conclusion:
Installing curtains in an RV requires a bit of customization, but the result is well worth it. With the right measurements, lightweight materials, and secure mounting, you’ll enhance both the look and comfort of your space. Find road-tested curtain options and RV-friendly guides at Hugmoom Curtain.
