RV Curtain Installation Tips for Tight Spaces
ttstt
Member
Installing curtains in a camper or motorhome has its quirks—tight corners, limited wall space, and the need for mobility-friendly materials. Here's how to do it right.
✅ Installation Tips:​
1. Use Adhesive Curtain Rod Brackets
No drill? No problem. Adhesive brackets are RV-safe and work well for lightweight curtains.
2. Opt for Lightweight Fabrics
Avoid heavy drapes. Linen blends, polyester, and cotton sheers are perfect for RV use—easy to wash, quick to dry, and wrinkle-resistant.
3. Install Track Systems for Sliding Curtains
For bunk beds or dividing spaces, ceiling-mounted curtain tracks work wonders. They allow for smooth, quiet movement and a clean look.
4. Velcro for Quick Fixes
In oddly-shaped areas, Velcro strips are a genius hack. Attach them along edges to hold curtains in place during travel.
5. Thermal Backing Helps Insulation
If you’re traveling in cold or hot climates, add thermal lining to keep the RV temperature stable and reduce energy use.
🪟 Small windows, big impact. Well-installed curtains can transform your RV from a vehicle into a cozy home.
👉 Discover RV-ready curtain solutions at hugmoomcurtain.com
