RV Neophyte
quote:
(1) What is the average length black water hose you want to have on hand? What do you do if the hose isn't long enough once you get to the camp site? :dead:
(2) Where do you go for oil changes? Truck stops?
(3) I know there are many variables, but what's the average gas mileage for a 29-30' Class C V10 engine?
We have now been fulltimers for four years and we have owned an RV of some type since 1974, so I will base my anwsers on that experience.
1) I would suspect that the most common waste hose is the 10' one. Which is best to use as your primary one depends mostly on the type of storage that you have. Our class A motorhome has a built in storage area that allows the hose to remain connected to the sewer dump when stored. For that reason I use a 20' hose as the primary one. And we also carry a connector for connecting two hoses together that is available at any RV supply store and an additional 10' hose. We rarely need the longer one and have never had any need to use any more than 30'. If we did we would just do as Gary B suggests.
2)Like most RVers, I do most of my own oil changes, particularly for the motorhome. That is a considerable savings and if you use one of the drain pans with storage in the bottom you can use that to take the waste oil to any store that sells oil for disposal. If not, then most tire stores can do oil changes on motorhomes. A few of the quick oil change shops will also do them.
3)Gas mileage depends upon many things besides the engine that your motorhome has. The weight and aerodynamics are major factors. The condition of the engine also plays a part. But the biggest single factor of all is the driver and how they drive the RV. If you make jackrabbit starts, wait until the last moment to apply the brakes and then brake hard, and drive at or above the speed limit for most of your travel, you will not get very good mileage. I have seen reports of mileage with the Ford, Triton V-10 that range from 5.5 mpg to as high as 10 mpg. Keep in mind that if you buy a new coach, that engine has a pretty long break-in period. Our mileage did not get very good until after we had more than 5000 miles and it really took 10,000 miles to settle into a steady pattern. And speed is a major player. With modern motorhomes, once you reach a moderate highway speed, each 5mph increase in speed will lower your mileage by 10%. We travel in a class A motorhome of 35' with an over the road weight very close to 18,000#. We accelerate gently when leaving a stop and we coast our speed down when anticipating a stop. And we usually have our cruise set at about 58mph. We average about 9.1mpg for most of our travel unless we are in mountains. We have gotten as low as 7.2 and as high as 10.3mpg.
This should give you some ideas to work with. The fulltime lifestyle should be a leisurely one with no ruch to get anywhere. After all, as the signs for home sales say "If you lived here you would be home now!" We do and we are!
